IPi Recorder User's Guide
Common
On-Screen Controls
- Enter full screen mode
Recorder
Setup
- Select working video mode
- Reorder cameras.
- Tip. For color cameras, it is recommended to place cameras in Recorder in the same order they go around capture area — either clockwise, or counter-clockwise. This will make calibration process in Studio much simpler.
- Note. Display settings you are making in the camera's on-screen controls do not affect the recorded video. For example, if you turn on mirroring, then image in video still will be unflipped, and if in depth + color mode you change the layout to display only depth, still both depth and color images will be present in video.
Background
