IPi Recorder User's Guide
Common
On-Screen Controls
- Enter full screen mode
Recorder
Setup
- Select working video mode
- Reorder cameras.
- Tip. For color cameras, it is recommended to place cameras in Recorder in the same order they go around capture area —either clockwise, or counter-clockwise. This will make calibration process in iPi Mocap Studio much simpler.
Background
