Recording a video from a depth sensor
Revision as of 15:22, 14 August 2012 by Pavel (Talk | contribs)
Environment
Side view
Top view
Actor Clothing
Recording Process
iPi Recorder Setup
Recording Actor's Performance
Performance Tips
  • Enter the actor.
  • Strike a T-pose.
  • Action
T-pose
Takes
Iterations
  • Record the videos
  • Give feedback to the actor
Takes
Naming conventions
