Recording actor's performance
Revision as of 15:31, 14 August 2012 by Pavel (Talk | contribs)
  • Enter the actor.
  • Strike a T-pose.
  • Action
Click to enlargeClick to enlarge
T-pose
Takes
Iterations
  • Record the videos
  • Give feedback to the actor
Takes
Naming conventions
