Processing a video from a depth sensor
- Run iPi Studio
- Press Ctrl+N or push “New” button on toolbar
- Choose recorded *.iPiVideo file
- In the “Select Video Layout” dialog select the following values:
- Depth video from MS Kinect Camera
- Numbers of cameras: 1
- Resolution: 640x480
- Right mouse button up
- Save created project by pressing Ctrl+S or pushing button “Save” on toolbar
- Switch to “Tracking” tab and push “Refit pose” button.
- As a result model should be matched with actor image from video. If it does not happen then delete result using item “Edit” -> “Delete pose” from main menu and repeat above actions.
- Using the slider right to the button “Show Skin” in toolbar, make sure that morph of model corresponds to the actor image. If no, than adjust arms/torso/legs morph using appropriate sliders from “Actor” tab.
- Switch to “Tracking” tab, check “Enable foot tracking” and “Enable shoulders tracking” checkboxes
- To start tracking just push “Track Forward” button
- Wait and watch...
