Cameras and accessories
Revision as of 17:08, 31 October 2011 by Pavel (Talk)
Recommended camera for use with iPi Desktop Motion Capture is Sony PlayStation Eye for PS3.
  • Low cost (under $40).
Cables
Tripods
Video Card
iPi Desktop Motion Capture relies on GPU for calculations. Therefore, it is recommended to use a fast GPU for processing recorded videos. As a minimum, you need a Shader Model 4.0-compatible (DirectX 10-compatible) GPU. Please be aware that desktop GPUs are dramatically faster than notebook GPUs (due to apparent thermal constraints in notebook PCs). To give you an idea of potential performance for various GPU models below are some benchmark results:
USB controllers
Under certain circumstances you may need to get additional USB controller.
