Cameras and accessories
Recommended camera for use with iPi Desktop Motion Capture is Sony PlayStation Eye for PS3.html>
[[File:Playstation_eye_small2.jpg]]
* High frame rate - up to 60 frames per second (important for reducing motion blur and capturing fast motions like dancing, boxing or running).
* Low-distortion wide-angle fixed optics.
* Efficient protocol for image transfer (saves more than 50% of USB bandwidth when compared to other webcams).
* Low cost (under $40).
== Cables ==
For distances over 5m, you should use [http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=active+USB+2.0+extension+cable&x=14&y=22 active USB 2.0 extension cables]. You can daisy-chain multiple active USB 2.0 extension cables for distances longer than 10m.
[[File:Active_USB_cable.jpg]]
When combining active and [http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=USB+2.0+EXTENSION+CABLE+TYPE+A+MALE+to+TYPE+A+FEMALE&x=5&y=19 passive cables], make sure that connection order is correct (computer->active cable->passive cable->camera).
== Tripods ==
Inexpensive 40- or 50-inch tripods like
[http://www.amazon.com/Zeikos-ZE-TR26A-50-Inch-Full-Tripod/dp/B001T9N0L2/ref=sr_1_18?s=photo&ie=UTF8&qid=1285026270&sr=1-18]
should be fine for use with iPi Desktop Motion Capture. It is recommended to place at least one of the cameras reasonably high (2 or 3 meters high) so you may need a high (72 inch or higher) tripod like [http://www.amazon.com/Professional-Carrying-DVL105U-DVL120U-Camcorders/dp/B002NV5E3M/ref=sr_1_56?s=STORE&ie=UTF8&qid=1285328810&sr=1-56] or some kind of ad hoc wall mounting solution.
[[File:Tripod.jpg]]
== Mini Maglite (or other flashlight) for calibration ==
You will need a small bright object for calibration. It is recommended to get [http://www.maglite.com/product.asp?psc=2AACELL Mini Maglite] (or other similar flashlight) for that purpose.
[[File:Maglite.jpg]]
== Video Card ==
iPi Desktop Motion Capture relies on [http://http://en.wikipedia.org/wiki/Gpu GPU] for calculations. Therefore, it is recommended to use a fast GPU for processing recorded videos. As a minimum, you need a Shader Model 4.0-compatible (DirectX 10-compatible) GPU. Please be aware that desktop GPUs are dramatically faster than notebook GPUs (due to apparent thermal constraints in notebook PCs). To give you an idea of potential performance for various GPU models below are some benchmark results:
[[File:Benchmark_tpf.png]]
== USB controllers ==
Under certain circumstances you may need to get [[USB controllers|additional USB controller]].
