IPi Recorder User's Guide
Revision as of 22:58, 21 August 2012 by VMaslov (Talk | contribs)
Common
On-Screen Controls
  • Enter full screen mode
On-screen controls
Full screen mode
Recorder
Setup
  • Select working video mode
  • Reorder cameras.
Selecting video mode
Reordering cameras
Camera properties
Background
Record
Setting recording parameters Recording in process Recording completed
Player
Converter
Tools
