IPi Recorder User's Guide
Revision as of 00:07, 22 August 2012 by VMaslov (Talk | contribs)
Common
On-Screen Controls
  • Enter full screen mode
On-screen controls
Full screen mode
Recorder
Setup
  • Select working video mode
  • Reorder cameras.
Selecting video mode
Reordering cameras
Camera properties
Background
Record
  • None
  • Background subtraction
  • JPEG (only for color)
During recording, some statistics are displayed, such as current file size, disk throughput, write buffer usage. Also you can bring up camera statistics on camera screens to watch for frame drops and related stuff. All those values may help you to discover performance issues. For example overflow of the write buffer signals that you have low disk speed — you can try to use more compression. Frame drops (if they appear only during recording) may indicate that your CPU is overloaded and you need to switch to less agressive compression options.
Setting recording parameters Recording in process Recording completed
Camera statistics
Good camera statistics Bad camera statistics
Player
Converter
Tools
