IPi Recorder User's Guide
Common
On-Screen Controls
- Enter full screen mode
Recorder
Setup
- Select working video mode
- Reorder cameras.
- Tip. For color cameras, it is recommended to place cameras in Recorder in the same order they go around capture area —either clockwise, or counter-clockwise. This will make calibration process in iPi Mocap Studio much simpler.
Background
Record
- None
- Uncompressed data. The lowest load of CPU, and the highest load of storage.
- Background subtraction
- Lossless computational-inexpensive compression. Gives compression ratio approximately in range 2..10. Some trade-off between CPU and storage.
- JPEG (only for color)
- Lossy computational-expensive compression. Gives compression ratio up to 100 and more, depending on setting the quality value. The highest load of CPU, and the lowest load of storage.
- Note. Use with caution for color cameras. Lossy compression reduces quality of the image, and may lead to more tracking errors. If you are forced to use it due to limited disk space/speed, leave the quality value at considerably high level.
Camera statistics
