IPi Recorder User's Guide
Common
On-Screen Controls
- Enter full screen mode
Recorder
Setup
- Select working video mode
- Reorder cameras.
- Tip. For color cameras, it is recommended to place cameras in Recorder in the same order they go around capture area —either clockwise, or counter-clockwise. This will make calibration process in iPi Mocap Studio much simpler.
Background
Record
- None
- Uncompressed data. The lowest load of CPU, and the highest load of storage.
- Background subtraction
- Lossless computational-inexpensive compression. Gives compression ratio approximately in range 2..10. Some trade-off between CPU and storage.
- JPEG (only for color)
- Lossy computational-expensive compression. Gives compression ratio up to 100 and more, depending on setting the quality value. The highest load of CPU, and the lowest load of storage.
- Note. Use with caution for color cameras. Lossy compression reduces quality of the image, and may lead to more tracking errors. If you are forced to use it due to limited disk space/speed, leave the quality value at considerably high level.
Camera statistics
Player
- Double-click on file in Windows Explorer. There should be association of .iPiVideo extension with iPi Recorder after proper installation.
- Drag and drop file to iPi Recorder window.
- Optimize screen layout — cameras in a row slider
- Hide background and see how well your action is distinguished from the scene
- Set priority on time or frames when playing — can drop frames switch. If it is off, then all frames are displayed during playback regardless of whether CPU can handle it at target frame rate or not. If it is on, target frame rate is maintained during playback, possibly at the cost of skipping some frames.
Converter
To start conversion, press ADD TASK button. You will be presented with file selection dialog.
After selecting a file, you get to the input parameters page. The layout of selected AVI file (kind and number of cameras, video mode) in most cases is determined automatically. In case of any inaccuracies, you can make manual adjustments. Layout parameters are the same that were used when opening AVI file in iPi Studio 1.x. Then press NEXT button to go to the output parameters page. Here you specify start and length of the background portion of the video. When dragging these sliders, a thumbnail for corresponding video frame is displayed to help you figure out proper values. Also you set compression options, which are essentially the same as in recording, but in conversion you should not bother about CPU load, because it does not require realtime performance. When all parameters are set, just press ADD button, and conversion begins (or is scheduled).
Tip. To save your time, you can select multiple files at once when adding conversion task. In this case they should all have the same layout (number of cameras and video mode), and also similar time boundaries for the background portion. Because all input and background parameters will be the same for all files. When specifying output file name you can use some placeholders for parts of input file name to make output file names differ from each other. For details, see tooltip for the output files pattern field. All output files are placed in the same folder. After pressing ADD button, multiple tasks will be added to the task list, one for each input file.
