IPi Recorder User's Guide
Revision as of 15:01, 22 August 2012 by VMaslov (Talk | contribs)
Common
On-Screen Controls
  • Enter full screen mode
On-screen controls
Full screen mode
Recorder
Setup
  • Select working video mode
  • Reorder cameras.
Selecting video mode
Reordering cameras
Camera properties
Background
Record
  • None
  • Background subtraction
  • JPEG (only for color)
Setting recording parameters Recording in process Recording completed
Camera statistics
Good camera statistics Bad camera statistics
Player
Player UI Background is hidden
Converter
Converter input Converter output Converter task list
Tools
  • CHECK FOR UPDATE
    Note. Daily automatic checks are performed during an apllication work. So you will not need to use this function unless you are in a real hurry for the last release (for instance, it contains a fix for some issue which is critical to you).
  • SHOW TRACE
    Shows the trace window. It contains diagnostic messages produced during an application work. When you experience some unexpected behavior of iPi Recorder, you can save the trace to a file and attach it to your report. The trace file may be very useful in determining sources of the issue.
Trace window
