IPi Recorder User's Guide
Common
On-Screen Controls
- Enter full screen mode
Recorder
Setup
- Select working video mode
- Reorder cameras.
- Tip. For color cameras, it is recommended to place cameras in Recorder in the same order they go around capture area —either clockwise, or counter-clockwise. This will make calibration process in iPi Mocap Studio much simpler.
Background
Record
- None
- Uncompressed data. The lowest load of CPU, and the highest load of storage.
- Background subtraction
- Lossless computational-inexpensive compression. Gives compression ratio approximately in range 2..10. Some trade-off between CPU and storage.
- JPEG (only for color)
- Lossy computational-expensive compression. Gives compression ratio up to 100 and more, depending on setting the quality value. The highest load of CPU, and the lowest load of storage.
- Note. Use with caution for color cameras. Lossy compression reduces quality of the image, and may lead to more tracking errors. If you are forced to use it due to limited disk space/speed, leave the quality value at considerably high level.
Camera statistics
Player
- Double-click on file in Windows Explorer. There should be association of .iPiVideo extension with iPi Recorder after proper installation.
- Drag and drop file to iPi Recorder window.
- Optimize screen layout — cameras in a row slider
- Hide background and see how well your action is distinguished from the scene
- Set priority on time or frames when playing — can drop frames switch. If it is off, then all frames are displayed during playback regardless of whether CPU can handle it at target frame rate or not. If it is on, target frame rate is maintained during playback, possibly at the cost of skipping some frames.
Converter
Tools
- CHECK FOR UPDATE
- Check our website for a new version of iPi Recorder. Please be patient — it can take several seconds to perform the check. You will see a message box stating whether a newer version is available. If it is, you should restart iPi Recorder — update will be performed automatically on the next launch.
- Note. Daily automatic checks are performed during an apllication work. So you will not need to use this function unless you are in a real hurry for the last release (for instance, it contains a fix for some issue which is critical to you).
- SHOW TRACE
- Shows the trace window. It contains diagnostic messages produced during an application work. When you experience some unexpected behavior of iPi Recorder, you can save the trace to a file and attach it to your report. The trace file may be very useful for us in determining sources of the issue.
