User Guide for Dual Depth Sensor Configuration (printable version)
Quick Start Guide
For the impatient:
- Get two Microsoft Kinect sensors, or ASUS Xtion Live sensors, or PrimeSense Carmine 1.08 sensors
- Get computer with DirectX 10 videocard and at least two USB 2.0 or 3.0 controllers
- Download iPi Recorder and iPi Mocap Studio
- Install iPi Recorder and iPi Mocap Studio
- Connect depth sensors to PC
- Note that both sensors can't be connected through one and the same USB 2.0/3.0 controller
- Point them at the actor (the angle between two depth sensors can be in the range 60-90 degrees, or near to 180 degrees)
- For calibration, take flat rectangular cardboard, and use iPi Recorder to record calibration video
- Please ensure that the calibration board is visible in both sensors. Turn the calibration board to the left and to the right, holding it vertically in front of yourself on outstretched arms.
- Record video of actor's performance. Please ensure that the whole body including arms and legs is visible during the performance in both sensors. Start from a T-pose. Then goes actor’s performance.
- Run iPi Mocap Studio to process actor performance video
- Import your character into iPi Mocap Studio (File >Import Target Character) to adapt the animation for your character rig
User Guide
USB controllers
- Very good low-light sensitivity.
- Low-distortion wide-angle fixed optics.
- Efficient protocol for image transfer (saves more than 50% of USB bandwidth when compared to other webcams).
- Low cost (under $40).
Cables
Tripods
Video Card
iPi Mocap Studio relies on GPU for calculations. Therefore, it is recommended to use a fast GPU for processing recorded videos. As a minimum, you need a Shader Model 4.0-compatible (DirectX 10-compatible) GPU. Intel integrated graphics is not supported
Please be aware that desktop GPUs are dramatically faster than laptop GPUs (due to apparent thermal constraints in laptop PCs). Laptops with switchable graphics should be configured to run iPi Mocap Studio on a discrete (high-performance) GPU.
USB controllers
- 2 depth sensors (MS Kinect, or ASUS Xtion, or PrimeSense Carmine)
USB hubs
Known compatibility issues
| ASUS Xtion (Live) | NEC µPD720200 (USB3) | Camera is not properly recognized by the system. | This firmware update makes device behave the same as PrimeSense Carmine 1.08 with this controller. |
| ASUS Xtion (Live) | VIA VT6212L (USB2) | Frame drops of color picture in 640x480@30 (depth + color). | |
| PrimeSense Carmine 1.08 | NEC µPD720200 (USB3) | Frame drops in 640x480@30 (depth + color). | Stable work in 640x480@30 (depth only) and 320x240 (depth + color). |
| PrimeSense Carmine 1.08 | VIA VT6212L (USB2) | Frame drops in 640x480@30 (depth + color). | Stable work in 640x480@30 (depth only) and 320x240 (depth + color). |
| PrimeSense Carmine 1.08 | VIA VL800(USB3) | Frame drops, reduced frame rate, freezes in depth + color modes. | Stable work in depth only modes. |
| Sony Playstation Eye | VIA VL800 (USB3) | Great number of bad frames and frame drops. Camera is invisible to iPi Recorder. | |
| Sony Playstation Eye | VIA VT6212L (USB2) | Great number of frame drop in 640x480@60 mode. | 2 cameras can work smoothly at lower FPS (up to 640x480@50). |
