Revision as of 11:41, 11 September 2012 by Andrew (Talk | contribs)
Step 5
Step 5
Animeeple
SegmentBone
HipHips
 LowerSpine---
  MiddleSpine---
   ChestTorso
    NeckNeck
     HeadHead
      Head|Site---
    (R/L)ClavicleCollar
     (R/L)ShoulderUpper arm
      (R/L)ForearmLower arm
       (R/L)HandHand
        (R/L)Hand|Site---
 (R/L)ThighUpper leg
  (R/L)ShinLower leg
   (R/L)FootFoot
    (R/L)ToeToe base
     (R/L)Toe|Site---
Step 5
Our user radiac published a tutorial about bringing animations to Blender (please note that this tutorial is a bit outdated as it does not take advantage of Blender-friendly export option):
Source Filmmaker
Please see the following video tutorial series on how to use iPi Motion Capture with Source Filmmaker:
