Performance Kinect
Revision as of 11:43, 11 September 2012 by Andrew (Talk | contribs)
Recording Actor's Performance
Performance Tips
  • Enter the actor.
  • Strike a T-pose.
  • Action
T-pose
Takes
Iterations
  • Record the videos
  • Give feedback to the actor
Takes
Naming conventions
