Editions Comparison
Revision as of 15:52, 10 March 2011 by Andrew (Talk)
A: Express Edition:
  • supports only 1 Microsoft Kinect sensor
Basic and Standard Editions:
  • you will also have bigger capture volume - 20 by 20 feet (approx. 7 by 7 meters)
  • and you will be able to capture more complex motions, including rotations with multi-camera set-up
Q: What is the difference between Basic Edition and Standard Edition?
Q: What is the minimum space required for capture?
A: For Kinect you will need 9 by 5 feet (3.5 by 2.0 meters). For multi-camera system (Basic or Standard Eiditon) you will need 18 by 12 feet (7 by 5 meters)
