IPi Recorder Setup
Revision as of 14:27, 13 September 2012 by Andrew (Talk | contribs)
Common
On-Screen Controls
  • Enter full screen mode
On-screen controls
Full screen mode
Recorder
Cameras stage
Setup
  • Select working video mode
  • Reorder cameras.
    Tip. For color cameras, it is recommended to place cameras in Recorder in the same order they go around capture area —either clockwise, or counter-clockwise. This will make calibration process in Studio much simpler.
Selecting video mode
Reordering cameras
Camera properties
Background
