Editions Comparison
A: Express Edition:
- supports only 1 Microsoft Kinect sensor
Basic and Standard Editions:
- support of 2 Kinects will allow you to capture more complex motions than with 1 Kinect, including rotations
- Sony PS Eye cameras-based set-up is the most powerful option: it will allow you to capture very complex motions in much bigger capture volume - 20 by 20 feet (approx. 7 by 7 meters)
Q: What is the difference between Basic Edition and Standard Edition?
A: The only difference is maximum number of webcameras supported (4 for Basic, 6 for Standard). 6-cameras set-up will allow you to track wider range of complex motions (including rotations, like fighting, dancing etc.) with good quality (more robust, more accurate).
Q: What is the minimum space required for capture?
A: For 1 or 2 Kinects you will need 9 by 5 feet (3.5 by 2.0 meters). For webcameras-based multi-camera system you will need 13 by 13 feet (4 by 4 meters)
