IPi Recorder User's Guide
Revision as of 14:41, 13 September 2012 by Andrew (Talk | contribs)
Common
On-Screen Controls
  • Enter full screen mode
On-screen controls
Full screen mode
Recorder
Setup
  • Select working video mode
  • Reorder cameras.
Selecting video mode
Reordering cameras
Camera properties
Background
Record
  • None
  • Background subtraction
  • JPEG (only for color)
Setting recording parameters
Recording in process
Recording completed
Camera statistics
Good camera statistics
Bad camera statistics
Player
Player UI
Background is hidden
Converter
Converter input
Converter output
Converter task list
Tools
  • CHECK FOR UPDATE
    Note. Daily automatic checks are performed during an apllication work. So you will not need to use this function unless you are in a real hurry for the last release (for instance, it contains a fix for some issue which is critical to you).
  • SHOW TRACE
