Revision as of 13:17, 25 September 2010 by Mini (Talk)
Space
For a multi-camera configuration, you need a minimum of 10 feet by 10 feet space (3 meters by 3 meters). At smaller space, actor simply won’t fit into view of cameras.
For 640 by 480 camera resolution, capture area can be as big as 30 feet by 30 feet (9 meters by 9 meters). That should be enough for capturing motions like running, dancing etc.
Background
Light-color background (light walls and light floor) is recommended for markerless motion capture. iPi Desktop Motion Capture is designed to work with real-life backgrounds. A multi-camera configuration (3 cameras and up) can handle certain amount of background clutter. Please keep in mind that the system can be confused if your background has large objects of the same color as actor clothes. Using a green or a blue backdrop may improve results, but you are not required to use a backdrop if you have reasonable office or home environment with light-color walls and bright lighting.
Lighting
Actor Clothing
Actor should be dressed in solid-color long-sleeve shirt, solid-color trousers and solid-color shoes. Deep, saturated colors are preferable. Casual clothes like jeans should be OK for use with markerless mocap system. iPi Desktop Motion Capture uses clothing color for separating actor from background and therefore cannot work with totally arbitrary clothing.
Special considerations
Don’t stand too close to a wall. Shadows on the wall may confuse the system. If standing close to the wall is unavoidable you should use additional light sources to light the wall behind actor to minimize shadows.
