IPi Recorder Changelog
Revision as of 22:04, 13 September 2012 by Andrew (Talk | contribs)
ver. 2.0.0.14
Version 2.0.0.14
Jul 21, 2012
Download-24.png  Download
 N E W    F E A T U R E S:
  • Improved error handling.
 B U G    F I X E S:
ver. 2.0.0.13
Version 2.0.0.13
Jun 14, 2012
WARNING. iPi Mocap Studio prior to version 2.0.0.132 may not open videos recorded with this release of iPi Recorder. Ensure that you're using the latest version of iPi Mocap Studio (see version info in Help -> About window). In case you need an update, try restarting application (an automatic update should launch), or download and run the latest installer from the downloads page at our website. Videos recorded with previous versions of iPi Recorder can still be opened by any version of iPi Mocap Studio.
