Space
For a multi-camera configuration, you need a minimum of 10 feet by 10 feet space (3 meters by 3 meters). At smaller space, actor simply won’t fit into view of cameras.
For 640 by 480 camera resolution, capture area can be as big as 30 feet by 30 feet (9 meters by 9 meters). That should be enough for capturing motions like running, dancing etc.
Background
Lighting
Actor Clothing
Special considerations
Don’t stand too close to a wall. Shadows on the wall may confuse the system. If standing close to a wall is unavoidable you should use additional light sources to light the wall behind actor to minimize shadows.
