FAQ
Revision as of 11:01, 25 February 2011 by Andrew (Talk)
Frequently Asked Questions
Q: Is tracking realtime?
A: No.
Q: And what about FBX?
Q: What does "iPi DMC" means?
Q: Is there version for Mac?
Q: How can I buy?
