FAQ
Revision as of 11:59, 25 February 2011 by Andrew (Talk)
Product Features
A: Express Edition supports only 1 Microsoft Kinect sensor. Your capture volume will be 7 by 7 feet (approx. 2 by 2 meters). You will not be able to track complex motions that include rotations because of self occlusion. But you will not need multi-camera system calibration, that makes Express Edition much easier in operation compared to other editions (that are multi-camera). Support of 1 Kinect is included in Basic and Standard Editions as well. You will also have bigger capture volume - 20 by 20 feet (approx. 7 by 7 meters). And you will be able to capture more complex motions, including rotations with multi-camera set-up.
Q: Is tracking realtime?
A: No.
Q: And what about FBX?
Q: What does "iPi DMC" means?
Q: Is there version for Mac?
Q: How can I buy?
