Revision as of 11:53, 7 November 2012 by VMaslov (Talk | contribs)
This page is not finished. Watch for updates in the nearest days.
What's this for
Equipment
  • PlayStation Move
  • Wii Remote with MotionPlus
    Note. Modern model Wii Remote Plus, which has MotionPlus integrated, should also be supported, but we have not tested it yet.
Important. If you don't already have Wii stuff, we strongly recommend to use PlayStation Move, because of its built-in magnetometer. In short, the presence of magnetometer gives a lot more stable orientation value. Without it, orientation tends to drift around vertical axis, and this leads to less accurate measurements. In addition, PlayStation Move's light sphere can be used as calibration marker (at least in some conditions).
Also, your PC should be equipped with a Bluetooth radio module to connect with motion controllers. If you do not have a built-in one, you'll need an USB Bluetooth adapter (like this one). And you will definitely need an USB to mini-USB cable to charge your motion controller and for initial wire connection to a PC.
Getting into Recorder
To get your motion controller in the list of devices, it must be connected to a PC via Bluetooth. But before it can connect to your Bluetooth adapter, the controller must be paired with it. That is where button ADD NEW helps. So, your first step is to press this button, select device type you have, and then follow the instructions specific for this device. For this process you will absolutely need mini-USB cable. Hope you'll make it from the first time. After pairing, the Bluetooth connection is established automatically each time you power on the motion controller.
Note. Pairing is one-time process unless you reconnect motion controller to another PC or gaming console. Each time you connect controller to another host, it should be paired.
After you have successfully paired the controller with Bluetooth adapter, it should be visible in device list. Mark it selected and go to Setup stage. Here for the first time you will see the controller visualized as a rotating blue "brick". And also you should see a message over it saying it is not calibrated. Calibration is needed for more accurate measurements, so it is highly recommended to get through it every time you see this message. To run calibration process, press CALIBRATION button in on-screen controls.
Basically, that's enough to start recording with motion controllers. More details follow soon.
Tips on action video
Will be written soon.
Tracking
After all, the sad news :( iPi Mocap Studio is not yet capable of using motion controller data for tracking. The update will be published in 2-3 weeks (this has been written on Nov 03, 2012). Use this time to get required stuff and make some test records!
