Revision as of 15:25, 23 November 2012 by Mini (Talk | contribs)
Step 5
Step 5
Animeeple
SegmentBone
HipHips
 LowerSpine---
  MiddleSpine---
   ChestTorso
    NeckNeck
     HeadHead
      Head|Site---
    (R/L)ClavicleCollar
     (R/L)ShoulderUpper arm
      (R/L)ForearmLower arm
       (R/L)HandHand
        (R/L)Hand|Site---
 (R/L)ThighUpper leg
  (R/L)ShinLower leg
   (R/L)FootFoot
    (R/L)ToeToe base
     (R/L)Toe|Site---
Step 5
Valve Source Filmmaker and DMX
    • open "Animation Set Editor Tab";
    • click "+" -> "Create Animation Set for New Model";
    • choose a model and click "Open";
Source Filmmaker
Please see the following video tutorial series on how to use iPi Motion Capture with Source Filmmaker:
