- Humanik Maya 2012 Part 6
Animeeple
- Click “Set first frame” on the “TPose” tab in import dialog.
- Assign bone mappings on the “Bones” tab:
| Segment | Bone |
| Hip | Hips |
| LowerSpine | --- |
| MiddleSpine | --- |
| Chest | Torso |
| Neck | Neck |
| Head | Head |
| Head|Site | --- |
| (R/L)Clavicle | Collar |
| (R/L)Shoulder | Upper arm |
| (R/L)Forearm | Lower arm |
| (R/L)Hand | Hand |
| (R/L)Hand|Site | --- |
| (R/L)Thigh | Upper leg |
| (R/L)Shin | Lower leg |
| (R/L)Foot | Foot |
| (R/L)Toe | Toe base |
| (R/L)Toe|Site | --- |
- Set the scale to 0.01 on the “Size” tab (by default, iPi Studio exports translations in centimeters for BVH files, while Animeeple expects translations in meters).
- Set “Root position: Y:” to a correct value on the “TPose” tab, or click “Drop to floor”.
- open "Animation Set Editor Tab";
- click "+" -> "Create Animation Set for New Model";
- choose a model and click "Open";
This was used until iPi Mocap Studio got DMX support. And still may be useful in case of any troubles with DMX. Please see the following video tutorial series: http://www.youtube.com/playlist?list=PLD4409518E1F04270
