FAQ
Revision as of 13:19, 25 February 2011 by Andrew (Talk)
General Questions
Q: What does "iPi DMC" means?
Product Features
A: Express Edition:
  • supports only 1 Microsoft Kinect sensor
Basic and Standard Editions:
  • you will also have bigger capture volume - 20 by 20 feet (approx. 7 by 7 meters)
  • and you will be able to capture more complex motions, including rotations with multi-camera set-up
Q: Is tracking realtime?
A: No.
Q: And what about FBX?
All editions
Q: Is there version for Mac?
A: Basically, you need:
  • For 5 or 6 cameras set-up you may also need additianl USB controller
Details can be found Cameras_and_accessories
Express Edition
Q: How can I buy?
