This page is not finished. Watch for updates.
What's this for
Equipment
- PlayStation Move
- Wii Remote with MotionPlus
Getting into Recorder
Note. For PS Move, pairing is one-time process unless you reconnect motion controller to another PC or gaming console. Each time you connect controller to another host, it should be paired. After pairing, the Bluetooth connection is established automatically each time you power on the motion controller. For Wii Remote, pairing should be done each time after Bluetooth connection is lost, either powering off the motion controller or the PC. This is another disadvantage of Wii Remote.
After you have successfully paired the controller with Bluetooth adapter, it should be visible in device list. Mark it selected and go to Setup stage. Here for the first time you will see the controller visualized as a rotating blue "brick". And also you should see a message over it saying it is not calibrated. Calibration of a motion controller (not confuse with calibration of cameras) is needed for more accurate measurements, so it is highly recommended to get through it every time you see this message. To run calibration process, press CALIBRATION button in on-screen controls.
- Select + Move — White
- Select + Cross — Blue
- Select + Square — Magenta
- Select + Triangle — Green
- Select + Circle — Red
- Select + T (Trigger) — Cyan
- Select + Start — Yellow
- Select + PS — Off
Tips on action video
Sorry guys, this was the wrong main thing :-/ After conducting some experiments while implementing motion controller support in Studio, we've come to the real two main things:
- At some moment during the record (for example, at the beginning), you should aim with (each) motion controller at one of the cameras. It is needed to correctly orient the motion controller within the scene coordinate space in iPi Mocap Studio.
- Tip. If you have already made some records without explicitly aiming at the camera, these videos may not be going to trash. Look thoroughly through all the frames — it is very likely that at some point the actor aimed at some camera by accident, at least in horizontal direction (this is sufficient).
- For better orientation of prop models in iPi Mocap Studio, hold the controller as if its side with buttons is a back side of a prop in a "standard" position — i.e. facing the actor's face when the arm with prop is stretched forward. Of course, you can use non-"standard" grip of the controller if such a grip for a prop is implied by the scenario of the action.
- Tip. You can use special accessories for motion controllers like [attachments]. In that case, the relative position of the controller to the prop is good known, so you just hold it as needed by the scenario.
Tracking
After all, the sad news :( iPi Mocap Studio is not yet capable of using motion controller data for tracking. The update will be published in 2-3 weeks (this has been written on Nov 03, 2012). Use this time to get required stuff and make some test records!
