This page is not finished. Watch for updates.
What's this for
Equipment
- PlayStation Move
- Wii Remote with MotionPlus
Getting into Recorder
Note. For PS Move, pairing is one-time process unless you reconnect motion controller to another PC or gaming console. Each time you connect controller to another host, it should be paired. After pairing, the Bluetooth connection is established automatically each time you power on the motion controller. For Wii Remote, pairing should be done each time after Bluetooth connection is lost, either powering off the motion controller or the PC. This is another disadvantage of Wii Remote.
After you have successfully paired the controller with Bluetooth adapter, it should be visible in device list. Mark it selected and go to Setup stage. Here for the first time you will see the controller visualized as a rotating blue "brick". And also you should see a message over it saying it is not calibrated. Calibration of a motion controller (not confuse with calibration of cameras) is needed for more accurate measurements, so it is highly recommended to get through it every time you see this message. To run calibration process, press CALIBRATION button in on-screen controls.
- Select + Move — White
- Select + Cross — Blue
- Select + Square — Magenta
- Select + Triangle — Green
- Select + Circle — Red
- Select + T (Trigger) — Cyan
- Select + Start — Yellow
- Select + PS — Off
Tips on action video
Sorry guys, this was the wrong main thing :-/ After conducting some experiments while implementing motion controller support in Studio, we've come to the real two main things (requirements):
- At some moment during the record (for example, at the beginning), you should aim with (each) motion controller at one of the cameras. It is needed to correctly orient the motion controller within the scene coordinate space in iPi Mocap Studio.
Now, the tips:
- If you have already made some records without explicitly aiming at the camera, these videos may not be going to trash. Look thoroughly through all the frames — it is very likely that at some point the actor aimed at some camera by accident, at least in horizontal direction (this is sufficient).
Tracking
When a project with motion data is first created, you will see this data as one or more colored "bricks" floating somewhere under the actor's model. To give more sense to this picture, for each controller you should specify a bone it is attached to. See the Attach to combobox. Currently it contains only LHand and RHand bones. This list will be extended as the support for other motion controller scenarios is implemented. When attached, the controller's "brick" is displayed near the corresponding bone of actor's model. For a nicer look, you have an option to replace the default brick with several prop models like sword and pistol. Currently, there are only few standard prop models. This list may be extended in the future, and the support for importing custom prop models is also planned. You also can change the main color of prop model, and toggle the display of prop's coordinate axes.
So you've done with the body tracking, and have attached the controller to a corresponding hand. Now find some frame where the actor is aiming with this controller at some camera (remember action video requirements?) Ensure the body position has been tracked in this frame. Select the target camera as the default, pressing corresponding toolbar button. Now you only have to press the Match with Camera X button, and that's it. After matching, the prop model for the controller should be oriented perfectly as it was intended in the video. Unless the actor has forgot about the proper grip of the controller.
