FAQ
General Questions
Q: What does "iPi DMC" means?
A: Exactly.
Q: How does it work?
A: It's just magic. This magic became possible due to tricky computer vision algorithms and GPU-accerated calculations.
Purchase FAQ
Q: How can I buy?
Q: Do you have any discounts?
Product Features
A: Express Edition:
- supports only 1 Microsoft Kinect sensor
Basic and Standard Editions:
- you will also have bigger capture volume - 20 by 20 feet (approx. 7 by 7 meters)
- and you will be able to capture more complex motions, including rotations with multi-camera set-up
Q: Is tracking realtime?
A: No.
Q: And what about FBX?
All editions
Q: Is there version for Mac?
A: Basically, you need:
- For 5 or 6 cameras set-up you may also need additianl USB controller
Express Edition
