FAQ
Revision as of 15:06, 25 February 2011 by Andrew (Talk)
General Questions
Q: What does "iPi DMC" means?
A: Exactly.
Q: How does it work?
A: It's just magic. This magic became possible due to tricky computer vision algorithms and GPU-accerated calculations.
  • It is optical markerless, so you do not need special costumes with markers or sensors
  • It woks with casual clothes
  • It works with real-life cluttered backgrounds so you do not need dedicated studio for capture sessions
  • It is portable. Real "motion capture in a backpack". You can set it up from scratch for 30-40 minutes, including calibration. Experss Edition set-up takes 10 minutes.
Q: Why should I believe you?
Purchase FAQ
Q: How can I buy?
Q: Do you have any discounts?
Product Features
A: Express Edition:
  • supports only 1 Microsoft Kinect sensor
Basic and Standard Editions:
  • you will also have bigger capture volume - 20 by 20 feet (approx. 7 by 7 meters)
  • and you will be able to capture more complex motions, including rotations with multi-camera set-up
Q: Is tracking realtime?
A: No.
Q: And what about FBX?
All editions
Q: Is there version for Mac?
A: Basically, you need:
  • For 5 or 6 cameras set-up you may also need additianl USB controller
Express Edition
