USB controllers
- 2 depth sensors (MS Kinect or ASUS Xtion)
USB hubs
Many modern laptops have one of the integrated USB 2.0 controllers reserved for docking station. That may effectively halve your USB bandwidth. Desktop PCs should not have such problem.
Before buying a specific laptop model it is strongly recommended to ensure it has the sufficient number of available built-in USB controllers and they are compatibile with cameras you intend to use. Find it at your local retailer, and bring cameras with you to test. Though it may be easier if your friend/neighbour has such a laptop. Or ask at our forum, maybe someone already used this model with our software or can recommend specific model for your camera configuration.
Known compatibility issues
Combinations of camera & USB chip listed below have known compatibility issues. If you need an additional USB controller for connecting specific camera, be sure not to get the one based on incompatible USB chip.
| Camera | USB chip | Symptoms |
| ASUS Xtion (Live) | NEC µPD720200 (USB3) | Camera is not properly recognized by system. |
| Sony Playstation Eye | VIA VL800 (USB3) | Great number of bad frames and frame drops. Camera is invisible to iPi Recorder. |
