USB controllers
- 2 depth sensors (MS Kinect or ASUS Xtion)
USB hubs
Many modern laptops have one of the integrated USB 2.0 controllers reserved for docking station. That may effectively halve your USB bandwidth. Desktop PCs should not have such problem.
Before buying a specific laptop model it is strongly recommended to ensure it has the sufficient number of available built-in USB controllers and they are compatibile with cameras you intend to use. Find it at your local retailer, and bring cameras with you to test. Though it may be easier if your friend/neighbour has such a laptop. Or ask at our forum, maybe someone already used this model with our software or can recommend specific model for your camera configuration.
Known compatibility issues
| Camera | USB chip | Symptoms | Comments |
| ASUS Xtion (Live) | NEC µPD720200 (USB3) | Camera is not properly recognized by the system. | This firmware update makes device visible to iPiRecorder. Depth-only modes are working good, but colorful modes suffer from low frame rate. |
| Sony Playstation Eye | VIA VL800 (USB3) | Great number of bad frames and frame drops. Camera is invisible to iPi Recorder. |
