USB controllers
Revision as of 10:33, 21 January 2013 by VMaslov (Talk | contribs)
  1. 2 depth sensors (MS Kinect or ASUS Xtion)
USB hubs
Before buying a specific laptop model it is strongly recommended to ensure it has the sufficient number of available built-in USB controllers and they are compatibile with cameras you intend to use. Find it at your local retailer, and bring cameras with you to test. Though it may be easier if your friend/neighbour has such a laptop. Or ask at our forum, maybe someone already used this model with our software or can recommend specific model for your camera configuration.
Known compatibility issues
Camera USB chip Symptoms Comments
ASUS Xtion (Live) NEC µPD720200 (USB3) Camera is not properly recognized by the system. This firmware update makes device visible to iPiRecorder. Depth-only modes are working good, but colorful modes suffer from low frame rate.
