What's this for
Equipment
- PlayStation Move
- Wii Remote with MotionPlus
Warning. With the current version of iPi Recorder, PS Move does not work properly on Windows 8. So you need a Windows 7 (Vista/XP) PC to use it. We are working on resolving this issue.
Getting into Recorder
- Select + Move — White
- Select + Cross — Blue
- Select + Square — Magenta
- Select + Triangle — Green
- Select + Circle — Red
- Select + T (Trigger) — Cyan
- Select + Start — Yellow
- Select + PS — Off
Tips on action video
Sorry guys, this was the wrong main thing :-/ After conducting some experiments while implementing motion controller support in Studio, we've come to the real two main things (requirements):
- At some moment during the record (for example, at the beginning), you should aim with (each) motion controller at one of the cameras. It is needed to correctly orient the motion controller within the scene coordinate space in iPi Mocap Studio.
Now, the tips:
- If you have already made some records without explicitly aiming at the camera, these videos may not be going to trash. Look thoroughly through all the frames — it is very likely that at some point the actor aimed at some camera by accident, at least in horizontal direction (this is sufficient).
Tracking
Tutorials and demos
- For those who do not like to read much, here is an introductional tutorial video from Joseph McPeek (aka Truebones)
- A great sample of hand tracking from Seed Crystal Games studio. Here you can also find a guide for attaching PS Move to a hand. Warning! Involves disassembling.
