FAQ
General Questions
Q: What does "iPi DMC" means?
A: Exactly.
Q: How does it work?
A: It's just magic. This magic became possible due to tricky computer vision algorithms and GPU-accerated calculations.
- It is optical markerless, so you do not need special costumes with markers or sensors
- It woks with casual clothes
- It works with real-life cluttered backgrounds so you do not need dedicated studio for capture sessions
- It is portable. Real "motion capture in a backpack". You can set it up from scratch for 30-40 minutes, including calibration. Experss Edition set-up takes 10 minutes.
Q: Why should I believe all that you say about your product?
A: Currently we offer email-based technical support. Please write to ipi@ipisoft.com
Purchase FAQ
Q: How can I buy?
Q: Do you have any discounts?
Product Features
A: Express Edition:
- supports only 1 Microsoft Kinect sensor
Basic and Standard Editions:
- you will also have bigger capture volume - 20 by 20 feet (approx. 7 by 7 meters)
- and you will be able to capture more complex motions, including rotations with multi-camera set-up
Q: Is tracking realtime?
A: No.
Q: And what about FBX?
Installation & Activation, Licensing policy
Q: Do you offer free trial?
Q: The system is requesting me to enter trial key. Where can I get it?
A: To obtain trial key please register to our user community forum: http://ipisoft.com/forum/ucp.php?mode=register. After registration please login to forum and take trial license key from forum’s “User Control Panel”.
Q: I haven't received activation e-mail after registration. What should I do?
A: If this happes:
- Make sure that this e-mail is not in “Spam” folder of your mail client.
- Check that you have entered correct e-mail address.
- Try to resend activation email. To do it, go to login page and click “Resend activation e-mail” link.
- If none of above actions help, please report the problem to ipi@ipisoft.com.
Q: How can I get license key?
A: No. According to our licensing policy, you can use 1 license key only for one computer, even if you do not plan to use the system on several computers simultaneously.
A: Purchasing the license, you get 1 year of free updates within the same major version (e.g. 1.x).
All editions
A: Basically, you need:
- For 5 or 6 cameras set-up you may also need additianl USB controller
Q: Is there version for Mac?
Express Edition
