Depth Sensors Comparison
Revision as of 12:26, 28 January 2013 by VMaslov (Talk | contribs)
Starting from version 1.8.0.81, iPi Recorder supports ASUS Xtion and ASUS Xtion Live devices (and also PRO modifications for developers). They are similar to Microsoft Kinect sensor and can be used in the same way. But there are certain differences that you can take into account before making decision on which device to choose for use with iPi Desktop Motion Capture (iPi DMC).
MS Kinect for Xbox or Windows
ASUS Xtion
ASUS Xtion Live
Kinect vs Xtion
Device Pros Cons
Microsoft Kinect
  • Require ACDC power supply
  • Only 30 fps frame rate
ASUS Xtion
  • Allow 60 fps frame rate (at 320 x 240 resolution only)
  • Less popular device
  • Lower drivers quality
  • Does not work with some USB controllers
Xtion Live vs Xtion
  • ASUS Xtion Live is recommended because it includes RGB sensor. RGB image is currently not used for tracking, but it helps to operate the system
Kinect for Xbox vs Kinect for Windows
  • If you plan to use Kinect not only with iPi Motion Capture, but also to have fun with Xbox games, then you definitely need Kinect for Xbox
  • But if iPi Motion Capture is all you need Kinect for, then Kinect for Windows has a couple of advantages over Kinect for Xbox
    • Kinect for Windows is officially licensed (by Microsoft) for commercial use (unlike Kinect for Xbox which is only licensed for personal gaming)
    • Since it is officially allowed to use with Windows, we may hope that drivers quality and support will be better
    • It has capability to track at low distance (from 40 cm). This is not useful for full-body motion capture, but may be helpful for other applications
  • You can use mixed configuration consisting of 1 Kinect for XBOX and 1 Kinect for Windows
