Revision as of 05:39, 25 September 2010 by Mini (Talk)
iPi Studio always exports a T-pose (or a reasonable default pose for custom rig after motion transfer) in the first frame of animation.
Create a Biped character in 3D MAX (“Create->Subsystems->Biped”). Go to “Motion” tab. Click “Motion Capture” button and import your BVH file.
Animeeple
  • Assign bone mappings on the “Bones” tab.
