Why
Mocap capabilities of iPi Mocap Studio lack tracking finger poses. Mainly because the resolution of input data is not sufficient for that. When it comes to hands, there is a need for employing the traditional keyframing technique in 3d party animation software.
However, when doing keyframing over mocap data, it is very convenient to have a video reference. Why not to do this right in the mocap software, which natively deals with video? Now you can. Meet the hand keyframing feature of iPi Mocap Studio.
Basics
- Manually edit one of the finger bones with the Rotate tool
- Click Insert Key Frame for Right Hand or Insert Key Frame for Left Hand menu item from the context menu of the timeline
- Paste a pose data containing the finger bones rotations from the clipboard
- Going to the last frame (same as double click)
- Setting one of the predefined poses like fist, relaxed etc.
- Deleting this key frame
Advanced
Notes
- When using the Paste Pose within ROI command, the finger bones are not touched. Use direct manipulation with hand key frames to massively edit finger poses.
- When editing the fingers pose in the middle of an existing key frame, it is automatically split in two parts. When editing the pose in the last frame of a key frame, its key pose is changed, and no new key frame is created.
- When manipulating with key frames, finger poses in all the frames involved in edit are automatically recomputed. However, as the keyframing feature is not mature yet, the software may fail to do it properly in some cases. As a workaround for such situations, there is the Recompute Finger Poses command in the context menu of the timeline. It forces the computation of finger poses in the whole animation from scratch based on existing key frames.
