FAQ
Revision as of 15:17, 10 March 2011 by Andrew (Talk)
General Questions
Q: What does "iPi DMC" means?
A: Exactly.
Q: How does it work?
A: It's just magic. This magic became possible due to tricky computer vision algorithms and GPU-accelerated calculations.
  • It is optical markerless, so you do not need special costumes with markers or sensors
  • It woks with casual clothes
  • It works with real-life cluttered backgrounds so you do not need dedicated studio for capture sessions
  • It is portable. Real "motion capture in a backpack". You can set it up from scratch for 30-40 minutes, including calibration. Experss Edition set-up takes 10 minutes.
Q: Why should I believe all that you're saying about your product?
A: Currently we offer email-based technical support. Please write to ipi@ipisoft.com
Purchase FAQ
Q: How can I buy?
Q: Do you have any discounts?
Product Features
A: Express Edition:
  • supports only 1 Microsoft Kinect sensor
Basic and Standard Editions:
  • you will also have bigger capture volume - 20 by 20 feet (approx. 7 by 7 meters)
  • and you will be able to capture more complex motions, including rotations with multi-camera set-up
Q: Is tracking realtime?
A: No.
Q: And what about FBX?
Q: Can Kinect with other cameras in multi-camera set-up?
A: No. Current version supports only one Kinect sensor OR multi-camera set-up.
Q: Can I use different USB cameras in multi-camera set-up?
A: No. Cameras should be the same model.
Installation & Activation, Licensing policy
Q: Do you offer free trial?
Q: The system is requesting me to enter trial key. Where can I get it?
A: To obtain trial key please register to our user community forum: http://ipisoft.com/forum/ucp.php?mode=register. After registration please login to forum and take trial license key from forum’s “User Control Panel”.
Q: I haven't received activation e-mail after registration. What should I do?
A: If this happens:
Q: How can I get license key?
A: No. According to our licensing policy, you can use 1 license key only for one computer, even if you do not plan to use the system on several computers simultaneously.
A: Please do not do that. If they use your license, this will be forbidding the terms of our license agreement.
A: Purchasing the license, you get 1 year of free updates within the same major version (e.g. 1.x).
All editions
A: Basically, you need:
  • For 5 or 6 cameras set-up you may also need additianl USB controller
A: We suppose you already have PC and DirectX 10-compatible GPU (with Shader Model 4.0 support). For Express Edition:
  • You will need Kinect sensor, the cost is around $150
For Bacis Edition (4 cameras):
  • Sony PS Eye camras + USB cables, the cost is around $180
For Standard Edition (6 cameras):
  • Sony PS Eye camras + USB cables, the cost is around $270
  • USB controller, the cost is around $30
  • Tripods (optional), the cost is around $80 (6 items)
  • SSD drive for video recording, the cost may be around $600
Q: Is there version for Mac?
Kinect Support (All Editions)
A: We use PrimeSense drivers and library to communicate with device via USB.
A: Yes. PrimeSense drivers we use are compatible with OpenNI.
