Depth Sensors Comparison
Revision as of 09:14, 7 March 2013 by Andrew (Talk | contribs)
Starting from version 1.8.0.81, iPi Recorder supports ASUS Xtion and ASUS Xtion Live devices (and also PRO modifications for developers). They are similar to Microsoft Kinect sensor and can be used in the same way. But there are certain differences that you can take into account before making decision on which device to choose for use with iPi Desktop Motion Capture (iPi DMC).
Microsoft Kinect for Windows
Microsoft Kinect for XBOX 360
ASUS Xtion Live
ASUS Xtion
Kinect vs Xtion
Device Pros Cons
Microsoft Kinect
  • Require ACDC power supply
ASUS Xtion
  • Lower interference with another ASUS Xtion sensor in "Dual depth sensor" configuration
  • Better RGB image quality
  • Less popular device
  • Lower drivers quality
Xtion Live vs Xtion
  • ASUS Xtion Live is recommended because it includes color sensor as well. Color image is currently not used for tracking, but eventually will. Also it helps to operate the system.
Kinect for Xbox vs Kinect for Windows
  • If you plan to use Kinect not only with iPi Motion Capture, but also to have fun with Xbox games, then you definitely need Kinect for Xbox
  • But if iPi Motion Capture is all you need Kinect for, then Kinect for Windows has a couple of advantages over Kinect for Xbox
    • Kinect for Windows is officially licensed (by Microsoft) for commercial use (unlike Kinect for Xbox which is only licensed for personal gaming)
    • Since it is officially allowed to use with Windows, we may hope that drivers quality and support will be better
    • Kinect for Windows has manual settings for RGB camera
    • It has capability to track at low distance (from 40 cm). This is not useful for full-body motion capture, but may be helpful for other applications
  • You can use mixed configuration consisting of 1 Kinect for XBOX and 1 Kinect for Windows
