Depth Sensors Comparison
Starting from version 2.1.4.21, iPi Recorder officially supports PrimeSense Carmine 1.08 device, which is essentially an equivalent of ASUS Xtion Live under different brand name.
Kinect vs Xtion / Carmine
Both Microsoft Kinect and ASUS Xtion (Live) / PrimeSense Carmine sensors are based on the same PrimeSense infra-red technology. So all basic characteristics critical for full-body motion capture are generally the same. But there are certain differences that you can take into account:
| Device | Pros | Cons |
| Microsoft Kinect |
| ASUS Xtion / PrimeSense Carmine |
Xtion Live vs Xtion vs Carmine
- ASUS Xtion Live or PrimeSense Carmine is recommended because it includes color sensor as well. Color image is currently not used for tracking, but eventually will. Also it helps to operate the system
- Note: ASUS Xtion and ASUS Xtion Live are also available in PRO modification (for developers). But the hardware is the same for regular and PRO versions, the only difference is in the software supplied with the device, that you will not need for use with iPi Motion Capture system
- PrimeSense Carmine has better USB 3.0 compatibility than original ASUS Xtion Live. However, there is a firmware update for ASUS, which makes both devices equivalent.
Kinect for Xbox vs Kinect for Windows
- If you plan to use Kinect not only with iPi Motion Capture, but also to have fun with Xbox games, then you definitely need Kinect for Xbox
- But if iPi Motion Capture is all you need Kinect for, then Kinect for Windows has a couple of advantages over Kinect for Xbox
- Kinect for Windows is officially licensed (by Microsoft) for commercial use (unlike Kinect for Xbox which is only licensed for personal gaming)
- Since it is officially allowed to use with Windows, we may hope that drivers quality and support will be better
- Kinect for Windows has manual settings for RGB camera
- It has capability to track at low distance (from 40 cm). This is not useful for full-body motion capture, but may be helpful for other applications
- You can use mixed configuration consisting of 1 Kinect for XBOX and 1 Kinect for Windows
