Revision as of 15:57, 20 March 2013 by Pavel (Talk | contribs)
Step 5
Step 5
    • open "Animation Set Editor Tab";
    • click "+" -> "Create Animation Set for New Model";
    • choose a model and click "Open";
Step 5
Step 6
