Sample video and project (four PS Eye)
Calibration Sequence
Here you can download sample calibration video file captured with the aid of four PS Eye cameras and appropriate iPiMocap project which is result of processing in iPi Mocap Studio:
| Download video file tutorial_4cam_calibration.iPiVideo 306 Mb | Download project file tutorial_4cam_calibration.iPiMocap 4.5 Mb |
How to use:
- Run iPi Mocap Studio, click Open button or press Ctrl+O and select tutorial_4cam_calibration.iPiMocap file downloaded on the previous step.
- Now you can "play" with resulting calibration data in iPi Mocap Studio, save scene parameters in .scene.xml file.
- select tutorial_4cam_calibration.iPiVideo file downloaded before;
- turn on Auto detect initial camera positions check box;
- then follow instructions to process video;
- the height of first camera over ground plane is about 1.10 m
Performance Sequence
Here you can download sample performance video file captured with the aid of four PS Eye cameras and appropriate iPiMocap project which is result of processing in iPi Mocap Studio:
| Download video file tutorial_4cam.iPiVideo 144 Mb | Download project file tutorial_4cam.iPiMocap 3.6 Mb |
How to use:
- Run iPi Mocap Studio, click Open button or press Ctrl+O and select tutorial_4cam.iPiMocap file downloaded on the previous step.
- select tutorial_4cam.iPiVideo file downloaded before;
- choose Action project type;
- load the following file as scene parameters:
- Gender = Male
- Height = 2.02 m
- Clothing model = Long-sleeve shirt
- then follow instructions to process video.
Exported Animation
iPi Skeleton for 3D MAX Biped for Motion Builder for iClone for Endorphin |
iPi Skeleton for Motion Builder for Endorphin |
iPi Skeleton |
Alyx Sandro |
Spy Medic |
