Sample video and project (dual depth sensor)
Calibration Sequence
Here you can download sample calibration video file captured with the aid of two depth sensors (ASUS Xtions in this case) and appropriate iPiMocap project which is result of processing in iPi Mocap Studio:
| Download video file dual_kinect_calibration.iPiVideo 99 Mb | Download project file dual_kinect_calibration.iPiMocap 0.8 Mb |
How to use:
- Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual_kinect_calibration.iPiMocap file downloaded on the previous step.
- Now you can "play" with resulting calibration data in iPi Mocap Studio, save scene parameters in .scene.xml file.
- select dual_kinect_calibration.iPiVideo file downloaded before;
- then follow instructions to process video
Performance Sequence
Here you can download sample performance video file captured with the aid of two depth sensors (ASUS Xtions in this case) and appropriate iPiMocap project which is result of processing in iPi Mocap Studio:
| Download video file dual_kinect_action.iPiVideo 54 Mb | Download project file dual_kinect_action.iPiMocap 1.2 Mb |
How to use:
- Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual_kinect_action.iPiMocap file downloaded on the previous step.
- select dual_kinect_action.iPiVideo file downloaded before;
- choose Action project type;
- load the following file as scene parameters:
- Gender = Male
- Height = 1.73 m
- then follow instructions to process video.
Exported Animation
iPi Skeleton for 3D MAX Biped for Motion Builder for iClone for Endorphin |
iPi Skeleton for Motion Builder for Endorphin |
iPi Skeleton |
Alyx Sandro |
Spy Medic |
