Video recording
Revision as of 19:57, 6 April 2013 by Andrew (Talk | contribs)
iPi Recorder Setup
Framerate
4 cameras at 320 by 240 resolution
4 cameras at 640 by 480 resolution at 60 frames per second
6 cameras at 640 by 480 resolution at 60 frames per second
USB controllers
