Sample video and project (dual depth sensor)
Revision as of 15:43, 8 April 2013 by Andrew (Talk | contribs)
Calibration Sequence
Here you can download sample calibration video file captured with the aid of two depth sensors (ASUS Xtions in this case) and appropriate iPiMocap project which is result of processing in iPi Mocap Studio:
Download video file
dual_kinect_calibration.iPiVideo
99 MByte
 Video-256.png         Proj-256.png Download project file
dual_kinect_calibration.iPiMocap
0.8 MByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual_kinect_calibration.iPiMocap file downloaded on the previous step.
  • Now you can "play" with resulting calibration data in iPi Mocap Studio, save scene parameters in .scene.xml file.
    • select dual_kinect_calibration.iPiVideo file downloaded before;
    • then follow instructions to process video
Performance Sequence
Here you can download sample performance video file captured with the aid of two depth sensors (ASUS Xtions in this case) and appropriate iPiMocap project which is result of processing in iPi Mocap Studio:
Download video file
dual_kinect_action.iPiVideo
54 MByte
dual_kinect_action.iPiMocap
1.2 MByte
How to use:
  • Run iPi Mocap Studio, click Open button or press Ctrl+O and select dual_kinect_action.iPiMocap file downloaded on the previous step.
    • select dual_kinect_action.iPiVideo file downloaded before;
    • choose Action project type;
    • load the following file as scene parameters:
      • Gender = Male
      • Height = 1.73 m
    • then follow instructions to process video.
Exported Animation
iPi Skeleton
for 3D MAX Biped
for Motion Builder
for iClone
for Endorphin
iPi Skeleton
for Motion Builder
for Endorphin
iPi Skeleton
Alyx
Sandro
Spy
Medic
