Clean-up
Cleaning up tracking gaps
- If necessary, use Rotate, Move and Inverse Kinematics tools to edit character pose to match actor pose on video.
Cleaning up individual frames
Note: after “Refit Pose” operation iPiStudio automatically applies Trajectory Filtering to produce a smooth transition between frames. As the result, pose in current frame is affected by nearby frames. This may look confusing. If you want to see exact result of “Refit Pose” operation in current frame you should turn off Trajectory Filtering (set it to zero), but do not forget to change it back to suitable value later.
Not all tracking errors can be cleaned up in iPiStudio using automatic tracking and Refit Pose button.
- Frames affected by strong shadows on the floor sometimes cannot be corrected. Typical example is push-ups. This is a limitation of current version of markerless mocap technology. iPiSoft is working to improve tracking in future versions of iPiStudio.
- Some other poses can be recognized incorrectly by iPiStudio. This is a limitation of current version of markerless mocap technology. iPiSoft is working to improve tracking in future versions of iPiStudio.
Tracking refinement
After the primary tracking and cleanup are complete, you can optionally run the Refine pass (see Refine Forward and Refine Backward buttons). It slightly improves accuracy of pose matching, and can automatically correct minor tracking errors. However, it takes a bit more time than the primary tracking, so it is not recommended for quick-and-dirty tests. Important. Refine should be applied with the same tracking parameters (e.g. feet tracking, head tracking) as the primary tracking in order not to lose previously tracked data.
Jitter Removal filter is a powerful post-processing filter. It should be applied after cleaning up tracking gaps and errors. It is recommended that you always apply Jitter Removal filter before exporting animation.
Range of frames affected by Jitter Removal is controlled by current Region of Interest.
Trajectory Filter is very fast. It is applied on-the-fly to current Region of Interest.
Trajectory Filter can be useful for “gluing” together multiple segments of animation processed with different Jitter Removal options: change the Region of Interest to cover all of your motion (e.g. multiple segments processed with different jitter removal setting); change Trajectory Filtering setting to 0 (zero); then change it back to 1 (or other suitable value).
